Battery charging packs
nonie
1,568
9
38
Looking for one of these. Any one have one they recommend?
Our elec was off yesterday for about 4 hours and Ofcourse when it went off I was about at 30%.
So thinking I need one.
If you mean charging cases have you checked mophie and zerolemon ? Usually they're pretty much the only makers of these unless you see something else on amazon. If you mean charging battery banks then idk i use a cheap one i got for emergency purposes.
I use imuto units bought on Amazon. I've been laid up after ankle surgery, and have been using my gadgets more than usual. Extension cords to plugs became a PITA. I first bought the 2000mAh unit, but it would charge the S8 only 3x. So, bought the 3000mAh unit, which, of course, has more capacity. Now, the wife will use these when she goes camping. Don't know how these compare to others, but work for me.
I don't like the big battery cases but I do have a battery pack that is 10,000 mah. I bought from Zagg.
Yes. Battery pack was what I meant, not cases. ☺️
After oue elec was off 4 hours, decided to get me one.
Also.... invest in good UPS. Nowadays they have USB port(s) you can run from for day.
I also keep one in basement (1000VA) just in case severe weather along with fully charged 24,000 battery pack. Also to provide power to lamp.
I have all my tv, computer and essential electronics connected to UPS as well.
Js42FL
