Battery cover makes clicking sound
msoprano13
222
does anyone have this problem?
it sounds and feels like the battery cover is loose and it pushes in the middle.
would a replacement solve this problem?
I have the same problem.. I guess a new cover would fix it but I don't want to pay for a cover..
Mine started doing that after a month or so. I cut a little sliver of plastic off a binder divided and put it under the cover. Seems to have solved it.
Twousay
