New to the Droid X and trying to get suggestions on battery and data settings. The search provides old information, before 2.2 update. Anyone care to share tips / hints? Thanks.
P.S. Any other tips / tricks / hints appreciated also.
I use the battery saver setting. If you go into settings and battery you will see it. It really helps with your battery life. I keep everything else on and I'm good for. About 14 hours which is all I need.
I keep my battery setting on 'Maximum Battery Saver' so it stops syncing data after 15minutes of inactivity day or night. I also keep all apps that have settings for automatic background updates (like Facebook) set to 'Never' & I have never missed anything yet.
