Battery Door Loose
miamifin33
427
4
So, my battery door slides off way too easily. Every time I take it out of my pocket, the door is off. When I move the phone in my hand, it'll slide off. Is there a fix for this?
Order a new one from verizon. Its like $3. Or perhaps the tabs are bent, visually inspect them. Or get the extended battery.
I saw a you tube video where the owner of the phone and very carefully with a tiny screwdriver bent(raised) the little clip the back slides over to stop it from falling off...gave the door a little more to holed on to...You could probably look it up it was for original droid but It should work for X
Mine was doing the sasme thing,slight pressure adjustment,and now its fine don't buy a new one......Plus its still under the year warranty,take it back have the back replaced.
Seeing that you came from the storm one, you should be familiar with the card/paper trick..............:D
Just kidding
Ha, what an awesome phone - it lets you keep 1/3 of a business card in the battery compartment so when the phone is locked up/rebooting/dead you can at least keep one contact via business card.
My battery door on my X is just fine. As a matter of fact, it's a pain to take off of my phone, and being that I don't need to take it off... works for me. :)
CeciliaBellh
