battery drain after update
  • Start date Start date
A
AC Question
I have a Galaxy S4 and last week my carrier decided to do some sort of update that has changed many of my setting, the biggest one and the one I can't figure out how to make stop is the battery the in the past lasted the entire day(depending on usage) now drains in about 3 to 4 hours and the biggest battery drain is Exchange service (version 4.2) with a wopping 56%, android system 20% and email 17%, my carrier is lets just say less than helpful. Thanks for your help, one of my employees is having the same issue.
Have you performed a factory reset? After an update such as that you should reset if problems are present. That should solve your issues.
qq77777881
