Battery Drain from Phone Calls
jtl
72
3
I have noticed that, since I have installed JD Ultimate, that my battery drains incredibly fast while I am on phone calls. I am rooted and have BAMF Forever 10.7 installed. Otherwise, JD Ultimate seems to be saving my battery...phone calls just seem to kill it. Does anyone have any advice? I have the latest radios installed and have not done anything else with the phone.
Thanks!
Thanks!
Since no one else wants to chime in... I'm guessing you are talking about Juice Defender... personally, I would uninstall it and test it... and I'm also guessing you are talking about version 1.0.7, you might want to try 1.0.8 and then the 1.0.9 patch to 1.0.8.... 1.0.9 is a little more optimized.
Thanks for the info. I will try that and see if it works. I meant 1.0.7
Do I have to wipe to do 1.0.8? I assume yes
The instructions don't specifically say... so I would not, but you might want to wipe cache and dalvik cache before installing, which will not hurt anything and your data will still be there. I'd wipe data if you started having problems you could not explain.
