battery drain is back
nadoxq8
14
when i got my s6 edge, there was a really bad battery drain which was fixed by doing a reset. 3 days ago, i noticed battery drain is back. a full charge, lasts me 2 days. but now only 14-16 hours. my usage is still the same.
any suggestions ?
s6 edge 64Gb (att)
Could you post a screenshot of your stats? This will help us to find out what is causing your drain.
I personally try and do a full battery drain every 1-2 weeks. Seems to be working for me as I'm getting excellent battery life.
I let the phone get to 1% so its turns off and then use the fast charger and charge it up to 100% without using it.
Today alone I'm on 55% battery life at 20:00pm in the UK with the phone usage being on 14 hours and SOT just over 2 hours.
Think that pretty good considering I've been using Spotify and YouTube since o got home.
Mines never went I got this phone 2 days after the release and had battery drain since day one but as everyone always complained about it. I guessed they would update and would fix. But since like I gt it I haven't done a single updatem .
I have done about 4 resets and none help it's a joke look at my stats on this image.
Then the 3rd image 5 minutes later look at the battery now it's an absolute joke. I charge this overnight. Charge mid day or it's under 40% then when get home from work it's on around 30 50% it's so so bad.
And as I pay 75 a month including insurance I am not turning WiFi and location etc off because a pine at that cost shud be fine. I regret leaving iPhone 6 plus now that lasted me all day with so mch screen on time
My battery never lasts me a full work day, let alone a full day.
I am a heavy user, however, performing much work and play on the phone all day. I expected better battery life, however.
I had a Note 4 before this, and even that didn't last me a full day so I didn't expect this to match that, but I expected better than it is now.
