Battery drain. Nothing new. How do I fix it on a KitKat?
A
AC Question
Battery drain.. Nothing new. How to fix it on a KitKat
Have an lg Droid w/KK. I keep having a problem with the battery dying in as little as 6-8 hours. I see that 'Media' and 'Media Server' are running under running apps. 'Media' has a stop icon and it is enabled but when I push it, it won't stop. Media service has no way to stop it. Doing the old turn off, pull battery.. No help. I have gotten those 2 services to stop in the past and the battery lasts 2 days. Don't want to do a full factory reset unless I have to.
Javier P
Ambassador
Feb 21, 2014
19,480
4
Re: Battery drain.. Nothing new. How to fix it on a KitKat
Do you have a SD card in your phone? Try unmounting it and see if it makes a difference.
Chris James L
Tried your suggestion for un-mounting the SD card. Didn't help. Media is using 30% and Media Server is using 23%. I tried 2 different appkill apps but didn't help. Thanks for the suggestion though.
Javier P
Ambassador
Feb 21, 2014
19,480
4
Hi Chris James, thanks for signing in. Welcome to the forums! Sorry for the delay, I missed your reply 😑
App killers aren't going to help you and sometimes they can be at the origin of the problem. I would disable them until you fix the problem. You could try clearing cache in your settings - storage and reboot your phone. If the problem persists boot your phone in safe mode to be sure if this is some problem with your system or a conflict with an app you downloaded.
