Battery drain notification
Trajikdroid
7
So for some reason I get a "This app is draining your battery" notification for everything I do. How do I disable this?? Its annoying as F.
What app is telling you that?
BTW, every app in use is draining the battery. If you are getting this message from a battery saver app, uninstall it. It is not only not needed, but drains your battery and gives you ads.
Go to Device Maintenance. Battery then press the 3 dots on the top left. Advanced Settings. Then turn off App Power Monitor.
dayssss2
