S Srikanth Sri1 Active member Mar 22, 2015 30 0 0 Apr 14, 2015 #1 My battery is draining fast on nexus 5 any solution for this??? Posted via the Android Central App
A AndroidDario Well-known member Dec 1, 2013 227 0 0 Apr 14, 2015 #2 Mine is drastically improved. Have you cleared your cache?
S Srikanth Sri1 Active member Mar 22, 2015 30 0 0 Apr 15, 2015 #3 Yeah I have cleared it.. But no improvement Posted via the Android Central App
E Eisen Berg Member Nov 11, 2014 23 0 0 Apr 15, 2015 #5 Check battery section from menu... Which apps are draining it?
S Srikanth Sri1 Active member Mar 22, 2015 30 0 0 Apr 15, 2015 #6 Screen is consuming more... Posted via the Android Central App
E Eisen Berg Member Nov 11, 2014 23 0 0 Apr 16, 2015 #7 Probably normal then. You use it so much If battery is old you could replace it...
