- Jul 20, 2013
- 7
- 0
- 0
my phone battery is draining fast. It happened before and i factory reset my phone then it was fine but later it started again but this time i dont want to factory reset my phone please help me to solve this issue
Main cause is background application install any task killer available on playstore.
it may seem zero but many bakcground processes are always on they again reopen wh you close them
keep brightness zero
turn off wifi bluetooth and data connection off when not in use.
still facing problem try formating or calibrate ur cell battery with following instruction once in every 2 months
undefined-Let the phone battery run out of charge, to 1 % or zero is better (preff 1 % bcoz zero battery can sometimes make your phone dead-then u hav to rely on phones warranty ) -remove battery after 15 min reinsert battery -Charge the phone fully without turning on your phone in one go with no breaks -Once it is fully charged, turn it on and leave it untouched for 30 minutes. -Again plug in the charger and allow it to charge for another 30 minutes, don’t use it in between. -Once the battery is fully charged, unplug it and your battery is now calibrated. hope your problem is solved .
