Battery drain
Cavidos
6
Hi.I'm using my Galaxy S2 for nearly two years.Now i have problems with battery.This problem came out a week ago.My battery goes from 38-45% to 1% just in a second.I think I should change my battery to new one.Am I right or is this problem more serious?
Sent from my GT-I9100 using AC Forums mobile app
If you have your original battery then yes buy a new one. My old electronics teacher told me the more you charge a battery the weaker the charge gets. So even if your battery has a "full" charge your battery can't hold the charge as long as it did from the start.
Hope that makes sense.
Sent from my SGH-S959G using AC Forums mobile app
Also. It would be wise to only charge your phone under 10% to ensure a longer battery life.
