Your screenshot shows a couple of things.
You have very bad signal and your phone is going to use much more battery because of that, specially when using mobile data.
Your awake bar is almost solid. It seems that you've got some background processes running almost non stop. Check in your battery stats which apps are using more battery. Also check your main sync/upload settings.
