Battery draining and heaps of data usage. How do I stop constant updates?
A
AC Question
Battery draining. When charging I'm getting notifications that Google+ and Google play are draining battery. How do you fix that
Data usage. Have used somehow over 800 mb in less than 2 days. No idea how. Luckily most of it is wifi. My first Android so maybe that's normal with all apps needing to be installed and stuff. I think 90% was from the Play Store too. How do I stop this?
Also how do you stop constant updates. Don't want any. Am using Asus Zenfone if that makes a difference
bramhast
