Battery draining fast!!
smooches680
1,026
3
38
I got my Samsung Galaxy Note 8 for a few weeks now and I love this phone but check out the attached note I stated the times and percentage of my battery draining. Is this acceptable or is this a problem with my phone?
Look at how fast my battery is draining and I am not even hardly using my phone unless I get a few texts messages. Not on Facebook or on the phone or the web. Crazy for me. Now it's 1:42 am and it's now at 38%. How can I fix this?
It can be caused by a lot of factors signal strength is a major problem what apps are syncing etc.
try running battery save mode it does help
Ok to help you best. Some info is needed:
WiFi on or off?
nfc on or off?
Bluetooth on or off?
Auto sync on or off?
What is your ommon brightness % ?
Which screen resolution have you chosen?
Do you have face book or Facebook messenger running?
Is your Canberra app open the the background.
Check these items as they can effect your battery life passively.
I have noticed that my Note 8 sample can happily keep games and apps running without reloading when I return to them. 6 gigs of ram is a lot but it may have an effect on battery life as well.
What I do is make bixby help me by automating the closing of unused windows after execting strings of system commands to open others. Most people don't close apps, they open one then another then another and another. We have even started to judge a phones performance by how messy wee can be with multiple unused apps holding their spaces in memory long after we have forgotten what or why we have opened them for.
I got my Samsung Galaxy Note 8 for a few weeks now and I love this phone but check out the attached note I stated the times and percentage of my battery draining. Is this acceptable or is this a problem with my phone?//uploads.tapatalk-cdn.com/20170922/7793f0947f39b29ee479286688dabe8e.jpg
What's the screen on time?
24hrs for 50ish% would be good depending on certain circumstances.
Please show us the battery stats.
Ideally you should install GSAM and enable the better stats via adb commands.
neophiyte
