• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
Battery draining problem with my galaxy s3.
A
AC Question
My device is draining battery so fast, i will try everything to do but there is something else.
Actually when i checked that to mobile repair shop
They said that its not the battery fault there is a fault of supply.
Any idea about how to fix it??
MobileNick
95
I'm not sure I agree with the repair shop, unless they can show you proof (for example, show the output of the phone charging circuit and prove to you that the output current is too low). S3 is now several years old so if it is the original battery would not be surprising if that has gone bad now - the battery is often the first thing to go bad. Fortunately, you can get a new one on ebay, etc., for a pretty decent price - certainly cheaper than repairing your phone.
I would take a chance and buy a new battery and see if that fixes it (unless like I said they have proven to you that the charging circuitry is bad). Just make sure to get an original Samsung battery - the aftermarket ones can start fires if you are not careful.
Rukbat
Retired Moderator
Feb 12, 2012
44,533
18
I would tend to disagree with your last sentence - both Anker and Hyperion are very good companies and both show batteries for the S3. (And "Samsung" batteries aren't always from Samsung.)
MobileNick
95
Agreed about those brands. By "...not careful" - I meant buying a no-name brand. You see a lot of those on ebay, etc.
