Battery Draining so fast
zobaid28
8
Hi m using lg g3 d856 dual. My device battery draining so first.its like 2/3 hours on screen time but stand by time is fair(like day long).M using lolipop 5.0.1 please suggest me what to do.If it shows last 3 hour use 9% means last 3 hour screen time was zero.Its draining if the screen is on and its fast!
Welcome to the G3 forum. :)
Charge fully, then use normally. Before you need to recharge at the end of the day, make a screenshot of your battery usage stats. We also need to know the screen-on time, and brightness setting, and also what your signal is like. Post the info here and we'll attempt a diagnosis.
Just look at this screen shot..stand by time good enough but SOT is not good
last 3 hour use shows 20% but 15 % droped just in 5 mnt SOT.
As a diagnostic, Force Stop or Disable the Clash Of Clans and Facebook apps and see whether that improves your battery life and SOT.
