I'm also not a fan of the account sync on android.
I found a nice tip somewhere to use the Tasker application to only perform periodic Syncs to your Google accounts. It's hard to quantify how much it helped, but I feel it's better for me.
This Tasker profile will turn on Sync ever 30 minutes for 25 seconds, then turn auto-sync back off.
Add a Time Context, set the From/To times to whatever period of time of day that you want the periodic sync to take place (8:00am to 10:00pm for me). Choose to Repeat every 30 minutes. This will perform the Task once per 30 minutes.
For the Task, Step 1 should be to turn Auto-Sync "ON" (auto-sync is under the Net category).
Step 2 should be a Tasker:Wait for 25 seconds (or longer if you find that sync is not occuring within that time period)
Step 3 should be a Net:Auto-Sync to "OFF".
This has been very reliable for me.
A few caveats:
- Of course, any mail received will not immediately be delivered to phone.
- I've also noticed that when "Sending" mail, it will not send the mail out til the next Sync (I wish there was an "auto sync on Send" setting).
Beyond just Google Account sync.. I'm also using Tasker to manage all my Wireless states..
- I leave Bluetooth on all the time.. it's what I use to trigger the below.
- When Bluetooth connects to my "UConnect" in-vehicle.. it turns off WifI, and turns on GPS.
- When I drive to within 1 mile of my house, is the only time that WifI is enabled by default.
If I were to purchase a Car-Dock, then I could have Bluetooth be disabled all the time, and only enable once connected to car-dock... this would save from it having to "search" for bluetooth all the time.
In general, check out all the stuff mentioned by others.. the if you're just looking to squeeze more out.. check out Tasker (pay-for in market) to see what it can do "for" you, so that you don't have to remember to enable/disable items at different times.
