Battery Drop
fofjjsr
Android4life
Aug 18, 2011
1,026
7
So, I was wondering if anyone else notices this. Today my battery was @63%, and I decided to do a restart. After the restart as soon as the phone booted up my battery now read 21%. 42% drop? Something is not syncing up. I don't know if it is just my widget, or the actually percentage. But the regular battery indicator definitely dropped. Anyone else experience this?
Edit: I use Battery Solo Widget as my battery widget.
I've definitely seen a big drop after a restart. Not quite that much though. I would imagine it is a combination of the algorithm being a little off to begin with and then trying to calibrate and estimate the battery life after the restart. I would play around with it and see if it continues.
Reactions: fofjjsr
And what can I do to "play around with it" as you state? Something in the settings? A app that will help out?
I am rooted also.
Also I don't always see that big a drop, sometimes it is like 10%, that was just the biggest one.
I think its normal especially if its usually 10%. I guess I meant fully charge it and try it or try it at different levels of discharge. But maybe someone else can help but I think it's normal.
The 10% doesn't bother me so much, but I have seen 20% and more, and like my most recent 42%.
I don't have any drop. Just restarted at 71% stayed at 71.
Sent from my SGS2 via Tapatalk
Yesterday I rebooted and it plunged off a cliff from ~55% to 12%. Unreal. What's the actually number? Scary.
This has happened to me a couple if times, however it is only after I drop the phone and it does a yard sale all over the ground. I have never seen the battery drop otherwise.
This only ever happened to me when I had a widget gadgeing my battery. Now that I've rooted and the ROM has one built in this never happens. Not sure why only widgets would do this but that's my experience.
sarahlouise
