Battery finally shows 100 % after 3 weeks
iEd
Banned
Jun 28, 2011
141
10
My battery finally shows 100 % after 3 weeks. I fell asleep with BT on WIFI data sync and the phone complety charged down to shut off after a full night charging it shows 100%
Lol sounds like you gotta train that battery! I have had mine now for 5 days and I get 100% during each charge...after it charges all night long. Otherwise it sits at 99%!
Strange!
Strange!
Good to know had mine almost a month and this morning was sitting at 98% instead of the 95% I was usually getting for the past few weeks.
Good to know had my almost a month and this morning was sitting at 98% instead of the 95% I was usually getting for the past few weeks.
Yeah! Yester morning mine was sitting at 97%. Its sorta strange.
I been using an widget called "Battery Indicator". I love it! It adds a battery% in your top task bar. It also gives you a ton of info on whats using your battery life! I love this widget plus its free! Check it out if you have not yet. It doesn't help with the 100% issue. Just great information.
I think my battery is fine though. ALOT better than my Pre- so I am good!
Reactions: B-Mod
Since 9 am after two long phone calls via Bluetooth sending texts and being on Wifi for about 5 min I'm down to 42% it's 2pm now
Weird mine is charging to 99% now and than dropping to 95% and still showing full charged while still on the charger ...
I than recharge it back to 99 and it sits there for awhile ... Why is HTC battery software so bad these days
When the battery is fully charged and still plugged into the charger, it's starts decharging, until you unplug and plug it back in. not sure how much it will "decharge".
Whenever I let it charge till it's green and at 99%, I plug it out, and right back in, and it goes back to orange for about 20 min before it decides it's full again.
That's what I was getting for 3 weeks till this morning when it started reading 100%
I haven't hit 100% yet and I got mine on Day 1. Every night I plug it in. In the morning the LED is green but the battery is only 98-99% full. I have discharged it to almost 0% and recharged it all night and it still won't go to 100% .
If you look at the Tips and Tricks sticky in this forum there is a suggestion I followed and got it to 100% on my first try. What you have to do is:
1. Charge until your phone light is green
2. Turn phone off while still plugged in and wait for light to turn green again
3. Unplug phone while it is still off and wait 5mins
4. Plug phone back in until it turns green again (took me 20mins or so)
5. Turn phone on and check for % (I had to repeat these steps 2-3 times in a row but it finally did it)
RohitPatidar57
