Battery for Nexus 6?
Paul Guest1
126
Should I worry about the battery in my Nexus 6? I kind of love the phone and see myself using it for a long time to come.
Whats your definition of a long time to come?
The battery should last you at least 2 years under normal usage.
Dont over heat the battery. Thats a huge factor in damaging a battery.
2 years is a good while. My battery is fine now, and I can imagine replacing it before choosing another phone, hence my question.
If you plan to use the phone for 2-3 years, you can probably just use the phone however fits your needs best and not think too much about it. If you're hoping for longer than that, then it may be worth more of the strategy approaches some have mentioned. For me, I'm generally getting frustrated with the speed of a phone by 2-2.5 years, and the battery has still been fine when I replace them with the 3 smartphones I've owned that long.
marksains61
