battery help please !! desperate
tashauphill
Active member
Jan 29, 2013
26
My battery is awful on my htc one sinse the update !! I have tried everything , removed certain apps , changed settings ! What more can i do ...i just drops by 5-10% in ten minutes !! Used to last me 2 days before the update .really fed up now ...always says android system is using like 80 percent ...
I know you don't want to hear this but I had the same issues. Lasted me 2 days until the update. I went ahead and did a full factory reset... Backed up everything first. Now it's back to normal with 2 days
Sent from my HTC One using AC Forums mobile app
Ive done a full factory reset and there has been no difference im afraid
Mine did the same thing mate I just used it until it turned it's self off then put it on charge while it's still off and left it over night and now it's back to awesome
Sent from my HTC One using Tapatalk
Sounds like there could be an active app that's running and draining your battery. Have you tried looking at the battery usage in the settings app to see what's being used?
kurniaa
