Battery help!
ahampton0217#AC
46
I've been having problems with my battery dies really quick even with am extended battery. No sooner I take it off charge its down to 94% with in 5 minutes. Any suggestions on what I can do my phone is rooted
Sent from my PC36100 using Android Central Forums
It's normal for it to go down to 90-94% after taking off the charger. How long does it take before the battery dies? What type of extended battery are you using? How old are your batteries?
With extended battery on all day but with the original battery couple of hours and my extended is a 3.7 VDC 3500 mAh I got it off amazon and the original battery is the original
Sounds like an app that is killing your battery. Check your battery usage and see if there is an app that is eating up the battery.
What ROM and kernel is your phone using?
I checked the battery usage and don't have any apps killing it just said display cell stand by and I have fresh rom on my phone and my keneral is 2.6.35.10-g13578ee
You can go all day with an extended battery on that phone?
Wow, you must be a light user
Sent from my SGH-T999 using Tapatalk 2
Yeah I don't do alot with my phone but with the old battery I couldn't get 4 hours out of it
How old is your 'old battery'? They do lose capacity over time and will eventually refuse to charge at all.
I usually buy a new battery every year for every day use and keep the old one(s) as spares.
quonishturftein
