battery help
jaybro0813
235
6
Any tricks to making Fascinate battery last longer? On the Droid Incredible they tell you to bump charge to get better battery coverage is there something we can do on the Fascinate?
what if I don't want to root or hack?
Well did you throughly read gunner's how to battery thread? You can't delete battery scripts if you arent rooted. Also give juice defender a try it will help a bit with battery life by limiting data usage and etc.
1. Dim the screen.
2. Limit background data and auto sync
3. Use darker backgrounds
4. Don’t use live wallpapers
5. Put the phone in airplane mode if you know you are not going to have signal
6. Turn off Wifi if you aren’t using it.
7. Disconnect from unused Bluetooth devices. If you aren’t using those head phones, disconnect from them.
8. Turn off Bluetooth*
9. Turn off GPS*
10. Use darker or black key boards
11. Dont use app killers.
ajr81
