S srfoot Well-known member Sep 6, 2010 225 4 18 Dec 28, 2023 #1 Hi. On pixel 8 pro, I have the battery icon as well as the percentage of battery showing. Is there a way to remove the icon and leave the percentage. Thank you.
rvbfan Well-known member Jan 17, 2015 2,371 2,506 113 Dec 28, 2023 #2 Not with stock pixel launcher. Might be able to do it with nova launcher or the like.
bkeaver Well-known member Apr 24, 2010 1,708 681 113 Dec 28, 2023 #3 No, there isn't even with another launcher. That is a rom level feature and no launcher is going to do that for you.
srvctec Well-known member May 29, 2011 878 78 28 Dec 28, 2023 #4 This has always been something that makes no sense to me (redundant for me) but I guess that's just the way it is.
mustang7757 Admin Moderator Moderator Feb 6, 2017 98,613 15,111 113 Dec 28, 2023 #5 Pixels can't change that by default only seen probably Samsung or One Plus
S srfoot Well-known member Sep 6, 2010 225 4 18 Dec 28, 2023 #6 Thank you all for your input. Reactions: B. Diddy and mustang7757
