Battery Increments?
droidX1991
118
Does anyone know how to look at how many percent your battery is at? and also to show it on the notification bar?
1 more question, where was that thread that showed you how to put a led notification on your screen?
To see the battery percentage, go to Menu / Settings / Battery Manager.
If you want the percentage to be shown in the notification bar, you can get Gauge Battery Widget free from the Market.
Download and use Battery Droid. It's got a widget you can put on your home screen with the percentage left. Works great.
layahhhh
