- Oct 10, 2015
- 290
- 0
- 0
I'm trying to troubleshoot a rebooting issue that I have documented in another thread. Long story, no so short.
My device has ran fine on 5.1.1 since I updated two weeks ago. I have a mildly depleted year old original battery (EB-BN910BBU) so I got another from AT&T free under warranty (also a EB-BN910BBU) and I also bought one off eBay (EB-BN910BBE). I have not used the replacement from AT&T yet. The eBay one is 100% genuine Samsung. QR code scans with serial number, laser engraving present under sticker, NFC is present and works, factory packaging, etc. I installed this eBay one and charged it to 100%. Seemed fine but only got like 3 hours of very mild use and then at around 40%, device went into a crazy reboot cycle. Happen twice back to back. Had to pull battery, reinstall, and reboot into recovery mode and clear system cache. Seemed to work. Also, I deleted an app the I sideloaded this same day, thought it may be causing the issue.
Yesterday, the battery lasted all day long. Took off charger at 4:45am and by 7:30pm, I still had 40% remaining but, it happened again at around this time. Random reboot loop that only a battery pull and recovery mode cache clear would cure. Rouge app I deleted is now out of the question. The only other thing I did since the 5.1.1 update other than install that one app was I re-encrypted my device and SD card two days previous to this new battery install. Seemed to be working OK. Last night after all these festivities, I unencrypted my device and SD to rule that out. So that's where I am right now.
But after all that, what I am trying to gather with no luck is info about this EB-BN910BBE battery. Did anyone's Note 4 come factory with this battery? I guess I can put the original battery back in or even the new AT&T one in but I kind of want to go step by step and see if this eBay battery is the culprit.
But again, if anyone has any knowledge of this EB-BN910BBE battery or if yours came with it when new, I'm all ears.
Thanks for reading my rambling.
