Battery Issues please help!!!
palanilopez12
155
So as you'll be able to see from my screen shots below I am getting horrible battery life! And I force stop apps such as Facebook and have turned off all notifications but it still seems to be keeping my phone awake. Any help would be appreciated.
What are your Facebook settings? I have mine set to only notify on comments not all that other stuff. I would check anything you have updating frequently. I manually update Gmail, Twiiter and FB. It makes a lot of difference. I also have GPS off, BT off and only turn them on when I need them.
What?! ... I'm msndrstood.
via Note II
via Note II
I actually have all Facebook notifications turned off. The app should be sitting there doing nothing at all. That's why I don't understand why its communicating so much when there's no reason for it to do so. Anyone else having this problem?
Hm.. Your phone is only waking up mostly when you wake it by turning on your screen. If you have any syncs going on this can cause the wake ups as well while you don't turn the screen on.
Sent from my Sprint HTC One using AC forums.
Do you have your data and WiFi turning off if you leave it sleeping with the screen off?
I thought the wake up time and screen on time are two entirely different things
- - - Updated - - -
No data is not turning off...my EVO 4G and EVO 3D never had this problem so why would this phone be any different?
cambium
