Battery issues recently...advice?
palanilopez12
155
I've been getting horrible SOT with my S9 plus recently and I don't know what is going on. I used to get 4.5-5 hours SOT no problem but now I can barely get 3 and I would have to be on WiFi all day for that to be accomplished. Any advice?
MrDoh
413
Can't tell exactly how strong your cell signal is, but it looks like only 2 bars. If it's low, that'll suck down your battery. So you should endeavor to use a femtocell (or "mini-tower" or "network extender" depending on your cell provider :), and make sure that wifi calling is enabled. When I have only one or two bars of cell strength, wifi calling is used on my phone. Not quite as good as strong cellular for battery use, but better than just a low cell signal.
palanilopez12
155
At works bars normally are 2 maybe 3 at a time. At home I'm always on WiFi calling
palanilopez12
155
Here is the latest screen shot
Gary_Berg
348
6
18
Biggest user is the phone radio. 49% is way high! When you are home you say you are on WiFi calling. As a test, while staying on WiFi try turning the cell radio off.
qqw999adsfdg
