- Jul 11, 2012
- 99
- 1
- 0
The past few days I've been getting less battery life than I usually get, with the same usage pattern. Usually when I get out of work after 10 or 11 hours, I'll be at 60-70%. Recently only 30-40%. Used two different battery monitors and they both are telling me that android system is using A LOT more than I've ever noticed. Using more battery percentage than my screen and my cell radio. I haven't changed my usage much at all. I did get nova prime and just started using it but I don't think that would effect it that much. It really seems like it's draining almost twice as fast, and it seems somethin in the Android System is causing it. I got a few Samsung account updates in the past week, anyone think that could be it? Or have any ideas or experiencing similar issues?
Sent from my SGH-T999 using Android Central Forums
