battery level does not show how long anymore?
lgbalfa
638
59
28
it only show how much time remains before it goes empty since the new update?
i liked how before it would tell me how long it has been off the charger.
maybe i can't find it?
I feel the same way, but you can find how long you've been off the charger, sort of. When you look at the graph, it shows when you took it off the charger, all the way at the left. It should show hash marks with a time underneath then (10am for example). I don't know how it works if you go more than 24 hours as I use mine quite a bit and usually charge it every night. But that can give you an idea going by the graph, it just doesn't display it in words anymore.
the best workaround i've found is to click on cell standby in the list of what's using the battery, the time in there will be how long since you last fully charged it
is there any other way to find out how long it has been since the last charge?
what I do is reboot my phone after unplugging from the charger. Then go into settings, about and status and it shows time since last reboot.
Like this? Sorry. What do you mean?
Sent from my XT1254 using Tapatalk
that is how it shows up now.
before it would tell you the time off the charger.
crayzeefoo
