- Oct 26, 2010
- 70
- 4
- 0
Hi. I got my transform 3 days ago and I love it so far. The only complaint is the battery life. I have NEVER had a phone that drained the battery so fast. I have the screen at the lowest brightness, all the screen and keypad timers at only 30 seconds, no wifi on, no gps on, no google locations on. Email only checking every hour, I don't have a ton of apps either. I have a task killer that I constantly use and make sure things are killed, and after all this it still goes to 30% only after 5 hours and only a total of 1 hour internet time.
Is anyone else having the same problem? Can anyone recommend a good battery manager? The ones I have seen don't seem like they do much other than allow me to change settings within the app that I can change anyway by going to the phones settings. Any suggestions??? It is sad that to enjoy a new phone for any good length of time you have to have all the bells ans whistles turned off or way low.
