Battery life is rubbish takes forever to charge, what can I do?
  • Start date Start date
A
AC Question
Battery life is rubbish. takes forever to charge
I bought my note 3 about a month ago and the battery was decent but now it only lasts around 3 hours and takes 8 hours to charge up , while being turned off. Ive replaced the battery and even done a factory reset but its still remained.Please help
Re: Battery life is rubbish. takes forever to charge
I have the same problem. My battery life also decreases on 1% by 3/4 minutes
Does anybody have a solution for this?
Thanks!
Change the battery and even better get a device with long lasting battery.
I wonder if you have a bad charger?
Bad charger, bad cable or bad charging circuit in the phone. Mine charges from 40% (which is the lowest you should discharge a lithium battery) to full (100% + 30 minutes) in under 2 hours. And the battery is over 2 years old.
(If you drain every last drop out of the battery every time, you can kill it it in a few months.)
GTomlinson
