Battery life on Note 10 (smaller)
I've not used the Note 10 but I wouldn't think it would be the same as the N10+ due to battery size difference.
Note 10 is 3500mAh
Note 10+ is 4300mAh
I use the N10+ 5G and can get 2-3 days usage however I always power down my phone at night as it's not needed during those hours.
Battery stats are a subjective topic as we all set up our phones differently, have different preference settings in the phone , use different apps, have different usage habits and have different signal strengths.
Biggest power drain is always screen brightness so depending on where you use your phone most will be a big factor, sunny country and mainly outdoor use will zap it nearly twice as quick as mainly indoor use in less sunny places
Battery life is subjective like those above me said. But I have the regular note 10 and this is what my battery life looks like currently on medium power saving mode and location on, so not bad I guess. A lighter user can probably stretch their standby time out a couple more hours based on those settings.
what is sleep pillow? can't find it on GP
No problem I know, I always thought that was the name but I guess not lol.
actually that IS the name. they chose not to show the name, but rather the description, in GP, as the name. once installed, I found it under sleep pillow. weirdness. I liked it and so did my dogs, but too ad heavy for my tastes. started hitting me up for money immediately. I already own so really great ones so no need to pay their prices for each one. I was just curious. thanks again.
No problem. I did pay for the ad-free version a couple years ago and have been using it ever since. They have a good mix of sounds to help me sleep.
I saw no version but that one and what it offered me was the option to pay $1.99 each for about 12 items or so. not gonna happen. I do appreciate it though. and I'd certainly pay a one-time fee, but not endlessly or with so many nags.
I get a slew of sleep apps but not that one
Sleep Pillow allows you to mix sounds, which is great for Type A personalities especially. The mixture of sounds confused my brain, which helps me fall asleep easier. There's a nice mix one in the free version that I've always used, but the paid version let's you mix your own and also gives you longer sleep timers.
