Battery life
SenseMonkey
1,773
15
Why do guys make it seem the battery on this phone is bad.? On my old phone ionly got 3 hours out of it untill it was at critical. On the one x,i havent charged it since iv got it from the at&t store. I've reached the 3hour mark with only 30% usage. This phone rocks. I know storage space is a little iffy cause i had 32Gb on my last one with 8 left but ill be set with the 16,or 12 i get with this one lol.
I get amazing battery life all the time check out this pic. 19hrs and 26 mins and still 46% battery left.....
Sent from my HTC One X using Android Central Forums
I've ordered my One X from AT&T premier (for the student discount) and as long as it gets better battery life than a LTE Galaxy Nexus I'm happy. And from what I've seen, it'll get plenty more.
I get about 10+ hours on mine. But I need to get a replacement on my hox. So I will report new battery life when I get a new one.
That is the move I made. I get twice as long.
Edit- I also do not have lte anymore :)
Fair to mention.
Sent from my HTC One XL using Android Central Forums
I get excellent battery life. If I don't use it heavily I can go two days before I have to charge. Under normal use, and when I say normal I mean on the Damn thing every 5 minutes, I can easily go all day before charging. As far as the memory goes it shouldn't be a problem, with all the cloud services available, i.e dropbox, it won't bother you in the least. You can configure dropbox to only upload on wi fi so you don't really have to worry about burning through data. This is a slick piece and you'll love it.
Thanks for the replies you guys,im still trying to do the whole discharge till less then 10% then recharge then discharge deal,i got 2 cycles left then ill be able to see how long this good sir lasts me.
... Because it is bad. Borderline terrible. 3 replacements from different stores. All the same. I get, on average, 7-10 hours max before it's in the single digits. Yes, I'm a heavy user. But that's no excuse. S3 had considerably better battery life (larger battery aside)
Still, I love the one x so I put up with it.
Sent from my HTC One X using Tapatalk 2
xxSlayer92
