Battery life
AJ Banks
What is the best approach to help save the battery and that actually will kill apss from running. I have 1 installed but it seems to not work.
Welcome to Android Central! Review these two articles first:
http://forums.androidcentral.com/am...how-tos/298919-guide-battery-saving-tips.html
RAM: What it is, how it's used, and why you shouldn't care | Android Central
Killing apps manually can often be counterproductive, since the app may restart automatically, because that's how Android works. If there are apps that you never use but keep starting in the background, either uninstall them (if you installed them in the first place) or Disable them in the Settings>Apps>All​ menu.
