Battery on S6 edge
SassiEduardo
Hi, i'm new here so if this is the wrong place to post i apologise in advance.
So i got my edge 32gb 2 days ago for a really good price here in brazil(SM-G925I) and my battery lasts for about 6-7 hour with moderated use. Is this normal?
Btw, my ram usage is ALWAYS ate 64%+. Is this normal? The sotware is up to date and i always close all my apps. I think that the high ram usage can be connected with the battery. Is this problem solvable(sic) or should i get a refund.
Thanks.
Welcome to Android Central! Is it 6-7 hours with the screen mostly on? If so, that's pretty normal. The screen is usually the biggest battery user, and normal screen-on time for a single charge is around 5 hours or so.
Android is designed to keep RAM relatively full, so don't worry about RAM usage, and don't make a habit of force-closing apps. If you force close an app, the system will just reopen it later or open some other app automatically.
Seeing some battery stats would be helpful. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/am...ide-how-post-screenshots-android-central.html
SeVeR
