You can only use batteries made for the ThunderBolt. The only larger battery than stock (1400mAh) currently available (correct me if I'm wrong) is the Seidio 1600mAh. So you can either use:
1. Stock battery (1400mAh)
2. Seidio Thin Extended Battery (1600mAh)
3. VZW/HTC Extended Battery (2750mAh)
