Battery overheating plugged in
Tibwolf
12
Is anyone else getting a message stating:
"Charging paused.
Battery temperature too high or low."
when making calls while plugged in?
My previous phone was an older Samsing smartphone and I never had any issue like this
Thanks
Have not gotten this yet. So far my Epic has been FAR more resilient to use while charging than my Touch Pro EVER was.
"Charging paused.
Thanks
Charging heats up the phone and using it at the same time seems like it could overheat the phone. Remember, this is a super smartphone and it can run a lot of tasks at the same time without you knowing. I suggest you check your task manager to see if anything else is running at the same time.
Nothing else but contacts and messenger were running. I've been trying to set my phone up for longer battery life.
I just thought it was odd that a 10 minute call on the charger would result in not being able to charge for another 10 minutes
Where was your phone?
I couldn't charge and use my Touch Pro in it's car cradle during the day. It got too hot, and the sunlight would just fry it.
You can also try extending the keyboard. Should give you more surface area to help dissipate heat...
Well, it seems like Samsung's got some software issues to iron out. Believe it or not, but battery life can be a software issue! I'm not to worried as I've gone through all these problems in other phones. However, I find it strange that my mom got 17 hours on her Epic yesterday and it would charge properly. My question is if these phones are lemons or if the batteries are lemons or if these issues are just some of those that just take a week to iron out. I vote for the latterest (lol, that's not even a word!).
"Charging paused.
Thanks
I actually just had this problem when I switched roms. The only solution I have found so far was to go back to the previous rom.
This was a problem on the EE03 and EF02 ROMs. If your phone has one of those ROMs, then that might be the case.
Sometimes when I am charging my phone I also get a message which states that the battery is overheating. At the stage where the message appears, the battery is still not fully charged.
What is causing this and what can be done about it?
Welcome to Android Central! How old is the battery? It might be failing. Try a new battery.
elnilphamari
