Battery percent for kit kat
The only thing I don't like is the number is not visible until your battery gets low. I guess that's when you need to know the percentage though.
Posted via Nexus 5
Perhaps this is a sign that a battery percent option is coming soon to Android?
Sent from my Nexus 5 using Tapatalk
Posted via Nexus 5
Looks that way as code is already built into KitKat.
Hopefully more options are available soon. I dont really like that one. You can use Fancy Widgets for a clock and you have the option to show the battery % next to the date.
I just a developer mod to get a stock percent. Its silly that Google still doesn't include this on stock android.
Battery reborn is also good and puts the percentage up top and in white to match the kit Kat theme.
Chris34728
