Battery percentage and always on display
night66owl
72
7
8
Is it possible to have the battery percentage in the middle of the screen of the always-on display instead of the top right corner?
No way to customize that, unfortunately (unless you disable the battery readout completely using GoodLock). You can, however, add a battery widget to the AOD, and you should be able to place that more centered and prominent on the screen.
I went to widget route, thanks
Sonfollower28
