Battery percentage doesnt match battery icon
rjenkin41
Active member
Jun 27, 2012
43
3
I'm new here so please bear with me if this issue has already been addressed. I made sure to Google it and I couldn't find anything helpful.
I'm having issues with my battery life. After about 2 hours of moderate usage (texting and browsing the Internet so I'm not even sure that counts as moderate usage), my battery loses about 35 percent of its power, which is a lot different from what I read on the forums and stuff. I made sure to check task manager and I'm using juice defender so I know I'm not completely jn the wrong here.
Long story short: is it possible that the percentage is reading a lot less than what the battery power actually is? The reason I say this is because the battery icon seems a lot fuller than the percentage indicated.
Again, please bear with me. I'm a newbie at this stuff so let me know what you think.
You said task manager. Is that something you downloaded from the market?
Sent from my EVO using Android Central Forums
no, sorry. What I meant is that I've been monitoring the cpu usage and nothing in particular is sucking up the power. If that makes sense
Nehasingh12
