Battery percentage indicator bug
nismo591
110
Anyone notice after charging their phone wirelessly that the notification in the task bar and any widget that displays the battery percentage stays at 99%? The only way to get it to correct itself is by reseting the phone. I know it's not a huge deal but bugging the heck out of me.
Can you see if the settings menu for the battery has it properly? I haven't noticed any issues, but I thought I saw a slight discrepancy between what the settings menu was showing and what the status bar was showing one time.
If I go into settings then battery it shows properly but the drop down indicator in the notifications does not. This only happens after wirelesslyccharging it overnight. A restart always fixes it though.
I'm using the Energizer pad and also don't have issues (finally had my battery power low enough last night to see).
Sent from my HTC6435LVW using Tapatalk 2
I'musing the lg Verizon branded charger. I was contemplating doing a factory reset to see if it fixes the issue. It does it every time I charge the devicetthat way so I can at least say it's not an intermittent issue.
Tested it today since I use the LG also, all seemed to track ok over the day went from 99 to 76 and the 'icon' looked similar to what 'battery' in settings looked like. I'll be flashing a mod that shows actual % later tonight.
Twousay
