Battery Problem. Please help me.
settusurf
5
Hi,
I had two issues for Note 2.
1. Every night my battery was drain upto 30% when i saw in the morning. No apps was running in the background and I also turned off the mobile data. I don't know why my battery drain upto 30%?
2. USB charging is very slow. Only 10% charge every 1 hour. Is it normal or problem in battery?
Thanks. Your reply is highly appreciated.
with those two issues combined it sounds like you have a bad battery or something, could you try a spare battery from some one?
The battery may be faulty based on problem #1 but not necessarily on problem #2. USB charging overall is slower but how much slower I'm not sure.
Yes, when charge on wall charger, it charge well...but in PC it is too slow....
That's normal. A PC USB can't provide enough power to charge quickly.
Sent from my Samsung Galaxy Note II using Tapatalk 2.
My fathers gn2 had a similiar issue. With his phone he was using an extra cable and charger he bought off ebay. Are you using stock everything charger wise?
Sent via Tapatalk
vik
