Battery Problems
ethan
168
My battery has gotten so poor, I can barely make it through half a day without having to charge it. I can't seem to find the problem either. I was thinking that because I use a dock at night it may have degraded the quality of the battery faster, but I'm not sure. Anyone have the same problem or any suggestions?
If you can, buy a new battery. Id go for the verizon extended battery. Its $50 but its very slim and hardly adds any thickness to the phone. My battery life is not the best, and this is the battery I plan on buying.
I haven't had the phone all that long, I had the D1 before, and the battery lasted much longer than this one, even though I did eventually have to replace it
And now it's taken to randomly not turning on the screen and then resetting itself. Any ideas what could be wrong here?
Yes, it was. Oddly enough, I took my brightness of auto and lowered it, it seems like this may have fixed (or at least made a little better) the issue. Will report back soon.
Well, that seemed to make it better for a few days, but now it seems to be back to its old fast drain. Still don't know what the problem is, and on top of that when I go into my battery manager it always immediately FCs. Any ideas?
khaled wali
