Battery Pull Required after every run of Bootstrap...
Callindril
62
5
Got everything setup and running with the 2.3.15 leak, and works great, but seems every time I try to use the Bootstrap app to go into recovery, it reboots the phone fine, but always hangs/locks on the "M" screen...Ive let it sit there for 20 min at a time, and it doesn't do anything...
If I do a battery pull during the "M"-Hang, it will sometimes reboot fine and run normally, sometimes boot into Recovery (Like I wanted it too), and sometimes will go back to the "M"-Hang, and require another battery pull...
Using Rom Manager to reboot and load something new does the same thing...
Is this normal, or is something not right on my installation?
Thanks
Cal
that doesn't seem right
i would try wiping data and cache, it seemed to help when mine did that
04ijordan
