Articles on battery life always say to limit your widgets. If you have a widget that is set to not update until you tell it to, does it really use that much battery life? For example, a weather widget that only updates when you click on the refresh button.
Also, if you are using a live wallpaper, does the battery drain that shows up in GSAM show under the app "Launcher"? I had a live wallpaper on and noticed that my "Launcher" was showing high battery use.
Sent from my HTC One using AC Forums mobile app
