battery replacement bad indicator
  • Start date Start date
A
Android Central Question
hey i had a problem me phone replacement battery and goes per night 1dropping down or 2 -3percent sometimes not dropping down when i lock with 75 , and next morning still 75 because i dont used the phone. example i see the battery left 7percent by 10.10pm and just lock the phone , next morning was 7percent , and just going down 1 percent per 7hours of not used the phone... but when i unplug from charger with 65percent it goes down per 8hours not used 52percent everything is OFF wifi,data.led. gps. nfc.
but when i reached to 21 percent i turned wifi always on,gps, wifi scanning, bluetooth scanning in gps settings, led notification, and nfc. after 10 hours of no usage , wifi always 10hours on, led notification 10 hours blinked when i received messenger sms,or facebook notification. its goes down just2 percent per 10 hours stand by. when reached 15percent i just turned led indicator and wifi is off gps, nfc. per 15hours of no usage goes to 12 or 13percent i dont remember , why baterry strange dropping down? but everyday discharging not the same percent down. when i got first time phone , i discharged to 10percent and after 10hours of not usage i still see the morning by 11;30a.m 10percent, not dropping any percent down
You've had so much trouble with your phones - you are a recognisable previous poster - that I think you ought to just get an iPhone and use it as recommended by Apple. It will be reliable. You will not have trouble.
