R rpdc Well-known member Jan 2, 2014 146 0 16 Oct 15, 2020 #1 Hi folks. The battery on my S8 plus is at 81percent capacity. With heavy use bearly able to get through the day. I plan on keeping the phone. Is it time to replace the battery or let it go a bit longer? Thanks!
mustang7757 Admin Moderator Moderator Feb 6, 2017 98,756 15,329 113 Oct 15, 2020 #2 If you plan to keep it longer, I would replace it .
mustang7757 Admin Moderator Moderator Feb 6, 2017 98,756 15,329 113 Oct 15, 2020 #4 rpdc said: Thanks Mustang! Click to expand... Your welcome!
