Battery runs hot
rxgadget
730
3
I have been concerned with my battery running hot in a regular basis. Using GSam and other battery monitors I am commonly above 104 degrees F. This is not always when on charger. I use the Turbo Charger downstairs and a Samsung 2.1 amp charger in other rooms. The is no difference in heat.
Sent using my Verizon Turbo charged 64GB Ballistic Nylon phone unfortunately with a case on back
what kind of battery life are you getting? Have you tried power cycling the phone?
Marabishi
